High idle at start
62,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
CHIBOW
When the engine is started when hot or cold it revs way up and then goes down to a slow idle. Idle almost to slow so when you turn the steering wheel it almost shuts it off.
Dec 12, 2018 at 1:32 AM
  • 55,562 POSTS
This sounds like you have a vacuum leak be sure to check the intake manifold as well. Here is a guide that will help us find the problem:
Cheers, Ken
Dec 14, 2018 at 4:03 AM
