High idle after cleaning throttle body
236,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
JDOODY8531
When first starting and engine is cool the throttle will drop a bit but immediately raises to 2,100 RPMs. It runs high in park, and while in gear.
Jun 5, 2022 at 8:23 AM
  • 55,694 POSTS
This can be because of two different factors either you have a vacuum leak because the sealing gasket got damaged when you reassembled the throttle body back into the engine, here, or the engine's computer needs to relearn which can take a day or two. Here is a guide to help you check for leaks and how to replace the gasket for the throttle body in the diagrams below:
and
https://youtu.be/Ui8zhMLp5EM
If everything checks out just drive the van for a few days and it should relearn the idle speed. Also are there any check engine lights on?
This guide can help:
Jun 6, 2022 at 5:40 AM
JDOODY8531
Thank you. I will check for a vacuum leak. I doubt that it will reset. I've tried but will give it a shot. This van is one I'm trying to get back on the road. I'll get back to you with the results.
Jun 6, 2022 at 11:02 AM
JDOODY8531
Also no check engine light.
Jun 6, 2022 at 11:03 AM
  • 55,694 POSTS
Yes, it sounds like a vacuum leak or relearn, let me know.
Jun 7, 2022 at 3:01 AM
