High Idle
1 MILES • 7.4L • V8 • 2WD • AUTOMATIC
TWEBB101
  • 183 POSTS
Hey all, question about my truck idling high. Stock Rochester 4BBL carburetor, which has been rebuilt. Truck starts right up and runs great. However, it seems to idle at a high RPM, and stays there. I don't have a tachometer in the gauges, so I'm not sure what number it runs at, but it does seem high to me. After startup I can hear when the engine warms up and 'levels out', but the RPMs do not slow down. Any thoughts on this?
Nov 21, 2021 at 6:36 AM
The most likely cause of this on a carburetor vehicle is the carburetor itself.
When this was rebuilt did you have it tuned or did you tune it so that you can set the idle and fuel mixture?
However, if it was then we can simply adjust it a little more the drop the idle until it is running slower and smooth.
First and foremost, you need to check and set the timing.
Based on the chart attached, you need to be around 4 degrees before TDC. If not, let's start with setting the timing correctly and then use the info attached below for adjusting the carb to see if you can lower the idle.
Please let us know what questions you have on this, and we can go from there.
Thanks
Nov 22, 2021 at 9:49 AM
TWEBB101
  • 183 POSTS
I did not have it tuned, nor did I adjust any of the screws. I just rebuilt the inside parts and reinstalled it on the vehicle. I have it set to 10 BDC right now. that’s what ASEMASTER6371 Roy told me…
Nov 22, 2021 at 11:14 AM
Yep. Roy is correct that most of these older vehicles like a little more timing advance because there are other parts that are worn. So, the timing compensates for that.
However, anytime you rebuild or refresh anything to do with the carb or ignition, you want to start back at factory settings and then adjust it from there to where this specific vehicle likes. You will know where this is by the way it is running.
Basically, you are going to be chasing this down a rabbit hole if you try to leave things set where they were and then you change something.
You may get away with it but if you think about it, those screw settings and timing were all set with a carburetor that was not rebuilt. Now that you have everything inside sealing like it should and clean, those settings are most likely not going to be okay.
So anytime I change something like this, you start back at the factory settings and make new adjustments. So, I would set the timing back to 4 degrees, then tune the carb so that you bring the idle down to where it should be. Then if it is not running smoothly, add a little more advance back to it so that it is running smoothly which will raise your idle again and you can then back that down again until it is idling where you want it.
It is a dance so just stay patient and if you get out of sorts, start over by setting it back to the factory setting and start over.
Based on all this, I suspect that you may back the timing down and it brings the idle right down to where you want, and you may not need to adjust the carburetor at all.
Nov 22, 2021 at 11:16 PM
TWEBB101
  • 183 POSTS
Thank you! I will try re-timing it this weekend and let you know how it goes. Can you tell me the purpose of this depression in the intake manifold, as it relates to the carb? I have 2 gaskets that came with my rebuild kit, one covers that depression, one does not. Which one is needed?
Nov 24, 2021 at 3:32 AM
The Quadrajet was used for many years. I think that cut out was started in the early 1970s.
It is to cut down heat-soaked components that will cause fuel boiling.
Plus, I am not positive, but it also helps with airflow balance between the bores.
Your carb should look like the first picture below and use the one with the cut out in the mounting gasket. They provide both just in case you have the older style carburetors.
Nov 24, 2021 at 5:50 AM
TWEBB101
  • 183 POSTS
Okay, thanks. Are those gaskets re-usable? Everything I find online shows me the gasket that has the tab in place (right-hand gasket in my picture).
Nov 24, 2021 at 6:01 AM
They look like they are composite gaskets, meaning they are not paper or cork, so they are reusable as long as there is no damage on the mating surfaces.
Nov 24, 2021 at 10:41 PM
TWEBB101
  • 183 POSTS
I pulled the vacuum line off of the distributor and timed it to 4 BDC, and the idle speed went down a bit. Put the vacuum line back on, and the timing line on the balancer jumped up to the 12-noon position, and the idle went back up. Is that normal behavior? Also, I tried adjusting the idle screw(s) on the carburetor, and nothing happened; I'm guessing those screws are stuck or broken?
*Correction: I was turning the idle mixture screws; I put those back and adjust the base/high idle screws, and the idle is much better now, down to about 700 RPMs. The timing mark is still up high though, about 1 o'clock now...
Also, the carburetor sounds like rushing water. is that just air being sucked in, and that sound is normally muted by the air cleaner?
Nov 28, 2021 at 4:41 AM
That sound is normal, and it is air being pulled in and pulling in fuel. It is dampened by the air cleaner, but I suspect if you have not heard that before that you had a vacuum leak.
Yes, when the line is reinstalled, the RPM will adjust slightly based on engine vacuum. If it is unstable then we need "t" in a vacuum gauge to the line so that we can monitor the engine vacuum.
However, if it is running properly and smooth then I would not worry about it. If you want to check your vacuum, then hook in the gauge and look at the page attached.
You should have a steady needle when the engine is idling and then when you spike the throttle, it will drop and then start to level back out when it comes back to idle.
Nov 29, 2021 at 6:22 AM
TWEBB101
  • 183 POSTS
If I'm building a basic street application, just standard driving, do I need to worry about "total timing"? Can I set it to 4 BDC, plug in the vacuum advance to ported vacuum on the carburetor, and be done?
Dec 2, 2021 at 7:34 AM
Yes. Technically the total timing on spark advance vehicles is just a check and adjust as needed. Basically, you set the base timing and the distributor will advance itself to where it is needed.
Race applications set total timing because they are looking for specific power at the higher RPMs, so they need to set the base timing so that the total timing is what they want achieved.
Basically, you are looking for best overall operation. So set the base timing at the best spot and then make sure you are not stumbling or other issues at higher RPMs. As long as you are not having issues at higher RPM then you do not need to adjust the base timing.
Dec 2, 2021 at 11:24 PM
TWEBB101
  • 183 POSTS
I think I’ve got the timing set right now, question on the function of the high idle cam. I understand the steps, and that it idles down as the choke warms up and opens. My question is: is the fast idle cam supposed to drop all the way down to low/curb idle on its own, or as the truck is driven? Right now, as the choke warms up, I have to tap the fuel just a bit and the cam will drop. Is that factory design/operation? Or is something not right?
Dec 26, 2021 at 4:17 AM
Yes. That is by design. When the engine completely cools down that cam will reset.
Then when you tap the throttle, it will drop the idle speed, but it holds it higher like this because we want to warm the engine as fast as possible. We need to warm the engine ASAP so that everything runs efficiently, and the metal components turn better when they are at the higher temperature. There is more damage done to the engine before it is warmed up than any other time.
So, keeping the idle higher until it warms up gets the engine hotter quicker. So that cam will keep the engine at a higher idle until you get in it and start driving it.
They actually do this with modern computer-controlled engines as well, but it is not as noticeable.
Great question. Thanks
Dec 26, 2021 at 7:48 AM
TWEBB101
  • 183 POSTS
Awesome, thank you!
Dec 26, 2021 at 7:56 AM
You are welcome. Thanks for continuing to use 2CarPros. We appreciate you coming back.
Have a great new year.
Dec 27, 2021 at 7:36 AM
