High idle
105,000 MILES • 3.0L • 6 CYL
JUGGALO45
  • 88 POSTS
Hi guys me again. You did such a good job last time with my crank no start that drove me crazy being a faulty relay. Well, car runs great ever since. but now it has a high idle (1,500 rpm's) until it is in gear (900) Any ideas?
Feb 13, 2020 at 11:37 AM
  • 110,248 POSTS
The most common causes of a high idle include an engine vacuum leak, fuel pressure issues, or a faulty or dirty idle air control valve. With that, here are links that explain how to check for a leak and fuel pressure. Also, the last two links explain how to service or replace an idle air control valve.
_____________________________________
To start, I have a link that explains about high idle issues.
https://www.2carpros.com/articles/engine-idles-too-high
https://www.2carpros.com/articles/idle-air-control-valve-service
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
_______________________________________
As far as the IAC valve, it is located on the throttle body. Do these checks and let me know what you find.
Feb 13, 2020 at 12:04 PM
