High idle
225 MILES • 2.0L • 4 CYL • 2WD
BIGFISHONE
Engine idle high when in park.
Nov 23, 2019 at 2:22 AM
SCGRANTURISMO
  • 4,897 POSTS
A high or "searching" idle is usually because of an engine vacuum leak. A vacuum link is described as any unmetered air that enters the engine from the Mass Airflow Sensor [MAF] to the engines combustion chambers. This includes the air intake tract, throttle body, intake manifold, vacuum hoses, PCV valves/hoses/ EVAP hoses, and Idle Air Control [IAC] hoses. Here is a link below explaining how to check your vehicle for vacuum leaks more thoroughly below:
Please go through this guide and get back to us with how everything turns out and what you are able to find.
Thanks,
Alex
2CarPros
Nov 23, 2019 at 5:36 AM
