High hydrocarbons
180,000 MILES • 1.5L • 4 CYL • FWD • MANUAL
ED303
I failed emissions test with high hydrocarbon numbers. it gets bad gas mileage, it misfires when cold, loss of power. When tank has quarter of gas car will want to shut off, only when I have about less than quarter take of gas, will not do it when full tank. Catalytic converter is okay, no check engine light. Car does not smoke or overheat.
Mar 30, 2017 at 2:13 PM
HMAC300
  • 48,601 POSTS
check your fuel pressure with a gauge auto parts rent it. the pressure may be too high or low but not enough to set a check engine light. then change oil and filter, air filter if dirty or not been changed in a long time then drive about fifteen miles on eway and then get tested.
Mar 31, 2017 at 12:37 AM
