High fuel consumption?
144,000 MILES • 1.0L • 3 CYL • TURBO • 2WD • MANUAL
ALIH
I have the vehicle listed above with a 1.3 diesel engine. It has high fuel consumption but runs normally. The mechanic said it might be the fuel pump, but can I drive with it? I have to get home and drive 600km the engine light is on.
Nov 1, 2022 at 2:58 AM
  • 55,721 POSTS
Poor fuel economy can be caused by many things but since the check engine light is on, we should start there first. Here is a guide to help you get the trouble codes which you can report back so we can go from there on to what is going to fix the problem.
Please go over this guide and report back.
Nov 1, 2022 at 4:01 AM
ALIH
just to mention when I bought the car the previous owner had canceled the DPF
filter system These are readings I got on my ODB:.
P0183
Status: Calibration Supported DTC, Current DTC, Test failed
time since DTC cleared, history DTC, test not complete since power on, current DTC since power on, warning indicator required
Possible decryption (attention control module):
OBDII: Fuel Temperature Sensor A - High Input General Electrical Failure
[0x00] Click here to search the Internet for description ...
P2453
Status: DTC Supported by Calibration, Test Failed Since DTC Cleared, Test Failed Since DTC Cleared, History DTC, Test
failed from power on Possible decryption (attention to control module):
OBDII: Diesel Particulate Filter (DPF) Pressure Sensor A.
circuit failure
Chevrolet: A sensor circuit fault in the Diesel Particulate Filter (DPF); Diesel Particulate Filter (DPF) differential
Incorrect installation of the pressure sensor circuit.
Diesel Particulate Filter (DPF) Differential Pressure Sensor Circuit
Algorithm Based Errors: High Temperature [0x54] Click to search internet for description ...
P2282
Status: DTC supported by calibration, Test has failed since time
Clear DTCs, History DTCs, Test Failed Since Power On
Possible decryption (control module note):
OBDII: Air Leakage Between Throttle Body and Valves
Chevrolet intake manifolds: Mass air flow sensor failure
(MAF) based on [0x52]
Nov 1, 2022 at 5:00 AM
ALIH
Hello, I would highly appreciate your quick reply please, as I need to drive 600km to get home today and I want to know if it's okay to drive? Thanks
Nov 1, 2022 at 12:59 PM
  • 55,721 POSTS
If there are no abnormal noises I would guess that you will be okay.
Nov 2, 2022 at 9:54 AM
