I have a problem with my high beams staying on when it calling for headlights. I'm trying to find the location of the dimmer relay on this model.
Nov 10, 2019 at 12:58 AM
DANNY L
✓Experienced Mechanic
First thing you might want to check is the headlight relay.It's located under hood in the #2 junction box.Here is a tutorial for you to view regarding how to test a relay:
I've attached 2 pictures below showing the exact locations and are circled in red.Hope this helps and thanks for using 2CarPros.
Danny-
Images (Click to enlarge)
Nov 10, 2019 at 10:05 AM
PLYMRR69
MEMBER
Thank you. I found the relay box for the dimmer relay. The relay box had become disconnected and was hanging in the engine compartment. It was a defective dimmer relay.
Nov 10, 2019 at 7:06 PM
DANNY L
You're welcome! Thanks again for using 2CarPros and please feel free to use us again in the future.
