I replaced the switch, the relay and the bulbs and my high beams do not work.
Oct 12, 2022 at 9:56 AM
✓Experienced Mechanic
When you checked or replaced the relay, did you confirm there is power to it as well as a ground signal when the high beam lights are requested?
Do me a favor. Take a look at this link. It explains how to test a relay and how to check for power to the relay. Check what is indicated and let me know the results.
