While driving with headlights on I turn on the high beams and all lights turn off
140,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
JOSHUA THURLOW
This happened twice now. While driving at night. Flip the switch to activate the high beams and after about 5 seconds, all lights go dark, are out for another 5 seconds or so, then light up again. This includes all interior lights and dash. When the lights come back, all the indicator lights on the dash, light up for a couple seconds. Similar to when the truck is started. Has yet to happen when just the low beams are on.
Dec 19, 2020 at 11:32 AM
  • 110,248 POSTS
It sounds like the switch could be the problem. I'm saying that since all lights are affected. Here are directions for testing the switch. You will be checking the resistance between specific pins on the switch. The attached pics correlate with the directions.
________________________________
2012 Dodge or Ram Truck RAM 1500 Truck 4WD V8-5.7L
Headlamp Switch
Vehicle Sensors and Switches Sensors and Switches - Lighting and Horns Headlamp Switch Testing and Inspection Component Tests and General Diagnostics Headlamp Switch
HEADLAMP SWITCH
DIAGNOSIS AND TESTING - HEADLAMP SWITCH
WARNING:
To avoid serious or fatal injury on vehicles equipped with airbags, disable the Supplemental Restraint System (SRS) before attempting any steering wheel, steering column, airbag, seat belt tensioner, impact sensor or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the SRS. Failure to take the proper precautions could result in accidental airbag deployment.
See pic 1
Remove the headlamp switch from the instrument panel. (Refer to 08 - Electrical/8L - Lamps and Lighting/Lamps/Lighting - Exterior/SWITCH, Headlamp - Removal) .
Disconnect the instrument panel wire harness connector from the back of the headlamp switch.
Using an ohmmeter, test the resistance or continuity between the terminals of the switch as shown in the Headlamp Switch Tests table.
Test
See pic 2
If the switch is good, then we need to check the totally integrated power module (TIPM). They are known to have issues with the connector pins failing.
Dec 20, 2020 at 3:04 PM
