When i pull back on the high beam lever the high beams will come on as long as i pull back, but when i push forward they will do the same but not stay on. The solid white wire on the round headlight switch connector is connected at the switch but not connected under the dash and appears to have come disconnected. What is this solid white wire and where is it supposed to be wired into? I cannot find a wiring diagram anywhere to show me the wiring of this switch and where the wires lead after the switch.
Oct 15, 2022 at 1:58 PM
