High battery draw down?
118,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
TENNISSHOES
  • 11 POSTS
Tracking down the draw and found that a fuse that should be nonexistent when pulled the battery draw drops to 001 Milliamperes, this fuse is located between 41 and 52 in the main power distribution box. When this fuse is pulled I loose the power port and OBD port data. All the charts I have found all say that there should not be a fuse there. Any thoughts or ideas?
Mar 31, 2026 at 12:29 PM
  • 55,721 POSTS
The fuse position 53 is the Cigarette Lighter - Accessory Power Outlet fuse, and that same circuit also feeds the DLC/OBD connector’s power. So is there anything plugged in to those ports?
Ken
Apr 1, 2026 at 2:53 AM
TENNISSHOES
  • 11 POSTS
No. Fuse 53 is not where I’m at, if you look at the fuse chart and you see fuse 41 and then you skip a place and then the fuse 52, in the place that the chart shows a skip I have a fuse in the space that causes the excessive draw, removing that fuse causes my power port to stop working and the data stream also stops in the OBD 2 port. Truck runs fine. So why is that fuse there and why the excessive power draw and why the loss of data when all the ECM fuses are good. Nothing external is added to this truck.
Apr 1, 2026 at 3:14 AM
  • 55,721 POSTS
They do not show a fuse between 41 and 52. So someone must have installed something in the blank slot? Can you upload an image of it so I can see, and you say nothing after market has been installed? Is this truck a hybrid? The power for the data port and the power port comes from fuse 53.
Apr 2, 2026 at 3:35 AM
TENNISSHOES
  • 11 POSTS
Here are the pics
Apr 2, 2026 at 3:37 AM
TENNISSHOES
  • 11 POSTS
Here is what I’ve got
Apr 2, 2026 at 3:38 AM
  • 55,721 POSTS
So you are pointing to an empty slot, no fuse goes in there and there is no metal terminals in that slot as well correct?
Apr 2, 2026 at 3:44 AM
TENNISSHOES
  • 11 POSTS
There are, that is where the draw is located. Pulled fuse the draw goes away.
Apr 2, 2026 at 3:45 AM
  • 55,721 POSTS
There are metal terminal connectors in the empty slot, yes or no?
Apr 2, 2026 at 4:21 AM
TENNISSHOES
  • 11 POSTS
Yes one got all the time the other has excessive draw on it.
Apr 2, 2026 at 4:40 AM
  • 55,721 POSTS
Can you please upload an image of the fuse position straight down where the mystery fuse is located?
Apr 3, 2026 at 1:07 AM
TENNISSHOES
  • 11 POSTS
Tried too. Can’t really see the contacts even in direct sunlight, but you can just barely see the little tiny silver rings in each slot.
Apr 3, 2026 at 1:44 AM
TENNISSHOES
  • 11 POSTS
Well the excessive draw just stopped, went from 0.53 to 0.17 then to 00., that took about an hour for it to get there and it didn’t come back so far, so I put it back together and will leave the testing meter on it all night and recheck in the AM. It’s been up for days, it totally killed the battery last week so I had to recharge a new battery, I have had a trickle charger on it this week just to stay ahead of the draw and now nothing. I’ll let you know it is returns.
Apr 3, 2026 at 9:35 AM
  • 55,721 POSTS
It may not have anything to do with this fuse, I don't see the terminals inside the fuse panel. Also, the battery draw you were seeing could be the computer system going into sleep mode, here is a guide that explains it.
https://www.2carpros.com/articles/car-battery-dead-overnight
It could be the battery is no good.
Apr 4, 2026 at 2:01 AM
TENNISSHOES
  • 11 POSTS
Did not explain why the draw would continue for three days then go to sleep. If the trickle charger was not connected the vehicles battery would have been dead. I’m going to be watching this closely.
Apr 6, 2026 at 3:04 AM
  • 55,721 POSTS
It sounds like the battery is going bad to me.
Apr 6, 2026 at 3:05 AM
TENNISSHOES
  • 11 POSTS
Nope, brand new battery. So here is what I have done, I split out the circuit from the fuse box, installed an inline fuse and connected it to the RV battery on the drivers side of the truck. So that way if it acts up again it will only affect the RV battery and not the main battery. I plugged in a voltmeter on the RV battery so u can watch the voltage on it. So when it sits like it does I can hookup a maintenance charger for that battery just in case. I know not the right way to do it but with it being intermittent I think it’s was the best way to isolate that circuit and fed with a separate power supply.
Apr 6, 2026 at 5:21 AM
  • 55,721 POSTS
Sounds good, did you go over the guide to see if any of the things mentioned are causing the issue.?
Apr 7, 2026 at 3:12 AM
TENNISSHOES
  • 11 POSTS
Only one draw was found. Everything else checked 0.01. Did a decent road test yesterday and it ran just fine. Let it sit overnight and of course the draw has not returned even in the new power system. So I’m going to go with it for now.
Apr 7, 2026 at 3:17 AM
  • 55,721 POSTS
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
Apr 7, 2026 at 3:35 AM
