HID headlights not working
130,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
BUMA
Headlights will not come on in either "auto" or "on" positions. Ambient light sensor is functional as instrument lamps dim/brighten as appropriate. Instrument panel headlight indicator is functional. Stack switch is functional. Relay?
Dec 6, 2018 at 11:13 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Did you test the headlamp control module? It is located in the engine compartment, near the front right side under the under hood fuse block. I have attached a tutorial for you to view. Hope this helps and thanks for using 2CarPros.
Danny-
Dec 7, 2018 at 10:56 AM
