ESP warning light came on and steering was lifeless?
62,903 MILES • 1.2L • 4 CYL • 2WD • MANUAL
JABEER AHMED
  • 23 POSTS
We did steering angle sensor calibration by scanner after doing the steering angle sensor calibration the steering felt lose and hours later ESP warning light came on and steering was lifeless in some speeds turn up your volume its making drrrrr noise and a tick noise when switching on ignition which wasn't there before, please help me.
Jan 29, 2024 at 4:36 AM
BRENDON S
  • 653 POSTS
Hello JABEER AHMED,
So, because this vehicle was never sold on the North American market, I don't have any data on the I20.
However, it should be close to the Accent so we can try using the information from that.
Let's see if we can narrow the possibilities down a little bit.
Can you tell me what you have for codes?
Also, what was the reason for the calibration?
If steering angle sensor was replaced, was an alignment done?
Thank you,
Brendon
Jan 29, 2024 at 5:55 AM
  • 55,851 POSTS
Thanks for the video. here is how the steering wheel angle sensor is calibrated which sounds like needs to be done again. This car is the same as an Accent. Please check the images below.
Calibration (Setting up the zero angle)
Steering Wheel Angle Sensor of an absolute angle type (CAN type) measures the angle under the standard of the zero-angle set.
Calibration must be performed as following cases.
Replacement of the Steering Wheel Angle Speed Sensor
Replacement or repair of the Steering column
Detection of DTC codes (C1260, C1261)
Replacement of the sensor cluster
Replacement of HECU
Calibration procedure
Perform wheel alignment and stand the steering wheel in a line within ±5°error.
Connect the GDS. (CAN line or OBD connector)
Turn the ignition switch on.
Press calibration button of the Steering Wheel Angle Sensor.
HECU calibration procedure is performed.
(Calibration records, DTC codes erasure)
Turn the ignition switch off after calibration procedure.
Confirm success or failure of calibration.
Warning lamp must not be lit when driving test (Turning left and right).
ESC lights ESC OFF warning lamp when making an error in comparison with values of other sensors.
Please let us know what happens, check the images below.
Jan 29, 2024 at 6:50 AM
JABEER AHMED
  • 23 POSTS
Hello, thank you so much for your response i have known the solution.
Jan 29, 2024 at 10:18 PM
JABEER AHMED
  • 23 POSTS
Hi, i wanted to know what is that tick noise that's coming?
Feb 5, 2024 at 3:51 AM
JABEER AHMED
  • 23 POSTS
After turning on ignition even after doing steering angle sensor calibration, that tick noise is coming, please help.
Feb 5, 2024 at 3:54 AM
JABEER AHMED
  • 23 POSTS
Please help about that tick noise when turning on ignition.
Feb 5, 2024 at 9:14 AM
  • 55,851 POSTS
does it happen when you turn the steering wheel? Can you give me more information and maybe upload a short video of the noise so I can hear it?
Feb 6, 2024 at 1:55 AM
JABEER AHMED
  • 23 POSTS
After turning off the car we when steering gets locked if we move then it make after turning on the tick comes again if we don't move the steering when it gets locked then it doesn't make. Near the blue circle it come what I've marked. And the steering is not properly calibrated i think it's not straight it's slightly left tilted of that it could make? Before i wasn't coming please help. It's tick noise before starting. It doesn't come in start.
Feb 6, 2024 at 3:26 AM
JABEER AHMED
  • 23 POSTS
I even saw in YouTube doing to other car same tick noise why is it.
Feb 6, 2024 at 5:55 AM
JABEER AHMED
  • 23 POSTS
In this car it's coming by doing steering wheel angle sensor calibration. please help.
JABEER AHMED
  • 23 POSTS
Near video ending tick noise.
Feb 6, 2024 at 6:04 AM
  • 55,851 POSTS
Thanks for the video. the clicking noise is caused by the power steering motor going out. Can I ask why you replaced the clock spring (spiral wire) in the first place? Here is how to change the power steering motor (MDPS). Check out the images (below). Please let us know what happens.
Feb 8, 2024 at 1:09 AM
  • 55,851 POSTS
anything?
May 10, 2024 at 9:22 AM
