Hi Is Showing 2 Codes 1 Is 7e8 The Other
37,554 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JASONANDMANDY
  • 6 POSTS
Car started as always no issues parked up at mums 4 an hour got in car started ok but wouldn't drive fully as only in limp mode. I did check codes and Internet it's saying it's the throttle position sensor
Dec 24, 2015 at 9:07 PM
HMAC300
  • 48,601 POSTS
if you read the code yourself you have to select engine first then get the code it should start with a P it should be a P0121 P0122 or P0123 I need the code in this format to help.
Dec 25, 2015 at 8:03 AM
JASONANDMANDY
  • 6 POSTS
Yes the code is p2126
Dec 25, 2015 at 4:44 PM
HMAC300
  • 48,601 POSTS
This code p2126 which is a throttle pedal position sensor. This can be the accelerator pedal is binding or bad pcm. This usually means the the throttle actuator has gone out and needs replacement. Here is a guide that will help you get the job done.
I would try cleaning the throttle bore first, disconnect the battery.
Please let us know what happens so it will help others.
Dec 25, 2015 at 10:50 PM
JASONANDMANDY
  • 6 POSTS
Hi again thanks for getting back to me yet again I've just been to the ford focus petrol 1.6 and removed the throttle actuator from a used car would that be okay to use? Will try cleaning the throttle body unit what do you think ?
Dec 25, 2015 at 11:24 PM
HMAC300
  • 48,601 POSTS
Just make sue you clean throttle plate on both sides before you install it.
Dec 25, 2015 at 11:48 PM
JASONANDMANDY
  • 6 POSTS
Okay will do thanks for are advice, it worked perfectly, thanks 2CarPros
Dec 25, 2015 at 11:51 PM
