Dash and turn signal problem
98,000 MILES • 5.8L • V8 • 4WD • MANUAL
ERMABRYAN
Only half of the dash lights work and the right turn signal don't work, also the four ways don't work unless you have the the turn signal on the right.
May 4, 2019 at 11:08 AM
  • 55,743 POSTS
It sounds like the dash cluster has gone out or you have a bad connection at the cluster. Please check all fuses and then remove the cluster to check for corrosion, If everything is okay try a used cluster. Please let us know what you find.
May 6, 2019 at 8:29 AM
