TCM location needed
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
PILITA JOHANSEN LAWSON
Can you tell me where the TCM is located?
Nov 22, 2020 at 5:47 AM
Your vehicle does not have a separate TCM. The PCM/ECM is the driver train control module. In other works, it does both.
Is there an issue that you need help with or was that the only thing you needed? Thanks
Please see the attached for the info from the manual on this.
Feb 24, 2021 at 10:07 AM
