Hi
134,000 MILES • 1.7L • MANUAL
VASILE
I have problems with my car when I start the car the battery light is on I drive 10 minutes and the car stop and all lights stays on I took the key out and still stays on,after 30 minutes start but same if I drive 10 minutes is stop again ,and the stearing problem when I drive slow is hard to turn the wheel ,what the problem can be? THANK you
Feb 9, 2016 at 6:38 PM
JOHNNYT73
  • 924 POSTS
Take the car to a parts store or shop to have battery/charging system checked. Your steering gets hard because when the car shuts off you lose power to your power steering pump, which is run by the engine.
Feb 9, 2016 at 10:23 PM
