Sorry for the delay.
If you are looking at one of the 3 relays to the left of the steering wheel then these are not one of the flashers.
Below you will find the info about how to test the flasher and the close up of the location. You will see this on the right side of the steering wheel closer to the center console.
In order to access this you are most likely going to have to remove the knee bolster which is the panel under the steering wheel. To do that, you need to remove any screws from the bottom of it and then pull it down as it will be clipped in at the top most likely.
Please run through this and let us know what you find. Thanks
Images (Click to enlarge)
Sep 23, 2021 at 11:05 AM
