Hey i need help
150,000 MILES • 1.5L • 4 CYL • FWD • MANUAL
OSCAR19941970
I am having problems with my car. Yesterday I was driving and my car just turned off. None of the dash lights are working, or the ignition switch. I had checked the fuses from under the hood and they seem fine. Not sure what is it?
Mar 29, 2017 at 9:09 AM
HMAC300
  • 48,601 POSTS
if check engine light is on scan for codes if not check fuel pressure with a gauge auto parts rent it. Often times this happens like you are having it just quits running due to be electric fuel pump. see link should be 30-38 with vacuum connected and 40-47 psi without.
Mar 29, 2017 at 11:11 PM
