hesitation when i push pedal
109,000 MILES • 1.4L • 4 CYL • FWD • MANUAL
CYRUS MORADI
In first and second gear the engine hesitating long and pushing the pedal does not help it at all.
clutch disk is new, but i wonder is it cause of timing belt or more likely diesel fuel filter or injector ?
it gets better from third gear that is why i think it probably is not because of timing belt.
Thank you in advanced.
Dec 1, 2016 at 5:40 AM
  • 55,837 POSTS
Hey Cyrus,
It sounds like you may have a intake boot that is torn and the mass air flow sensor is getting a false reading because of it.
Here is a guide that can help you run some test and get back to us so we can help.
https://www.2carpros.com/articles/engine-hesitates
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Dec 4, 2016 at 5:09 AM
