hesitation, pausing while accelerating
270,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
JOE GDOWIK
While accelerating mainly around 1.75-2.75 rpm's the engine hesitates/pauses then accelerates more then pauses again, after 2.75 rpm's is reached there is no problem.
Recent work done: transmission flush and filter, harmonic balancer, idler pulleys, belts, water pump and timing belt, mass airflow sensor, knock sensor, valve cover gaskets, spark plugs, wires, distributor cap and rotor, fuel pump, fuel filter, fuel pump relay.
Original transmission and engine.
Nov 12, 2016 at 9:43 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. try cleaning throttle plate on both sides with choke cleaner and IAC holes. See link for fuel pump check.
Nov 13, 2016 at 12:23 AM
