This is normally caused a failed engine mount or transmission mount. Basically when they fail and the AC adds the additional load or stain to the engine it causes it to shake. More than likely it will get worse and start shaking or vibrating all the time.
There is a chance that there is a vacuum leak but I would start with the mounts.
Here is a bunch of info on the mounts. Let me know if you have questions.
I will check the engine mounts. but, why is it that the rpm's will go down when the AC is turned on? That's when the car shakes a little bit and notice the rpm needle moving up and down. The car never shuts off but feels like it would. If I turn the AC off it works fine.
Dec 8, 2019 at 10:16 PM
✓Experienced Mechanic
I would service the throttle bore first. Please let us know. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
