I've put all new coils, plugs, crank sensor, TPS, and camshaft sensor idle air control valve. New PCV valve new vacuum lines. I've probably put $1,500.00 in new parts. When I first take off it feels like it's starving for fuel but once the rpm's get to 3,000 and up it runs fine. Once I'm up to 55 to 60 mph it does good unless I put it in overdrive then it starts stumbling again, but turn off the overdrive it's fine. Also if I I shift it manually once it hits 4,000 rpm's it's like a turbo kicks in. Any advice? please help. Thanks, Preston
May 6, 2020 at 12:53 PM
