The vehicle hesitate at load condition or high speed.
May 14, 2016 at 4:38 AM
SATURNTECH9
✓Experienced Mechanic
Are you setting any codes in the computer? you could have a coil starting to go bad.
May 14, 2016 at 5:53 AM
MILTON BASKETT JR.
MEMBER
I had a check engine light on had catalytic converter clogged. It was fixed so the check engine was turned off. The SUV had a hesitation problem with the catalytic converter problem also. This was told to mechanic. I changed air filter, but problem has not stop.
May 14, 2016 at 8:40 AM
MILTON BASKETT JR.
MEMBER
on the answer, the vehicle has no codes showing.
May 14, 2016 at 9:01 AM
SATURNTECH9
Is the hesitation worse with the the air conditioner on?
