Hesitation after replacing the ICV and MAP sensor, also the check engine light is on?
81,000 MILES • 2.2L • 4 CYL • AUTOMATIC
JS5878
I replaced the ICV (idle control valve) and MAP sensor, and now it hesitates when I drive, lunges forward, before it would stall on me, before I replaced these items. Check engine light appears also.
May 12, 2023 at 7:19 AM
  • 110,248 POSTS
If the check engine light is on, you really should have the computer scanned for diagnostic trouble codes. That will point us in the right direction.
Here is a link that explains how to perform a scan of the entire controller area network:
If you don't have access to a scan tool, most parts stores will do it free of charge.
Let me know what you find.
May 12, 2023 at 3:01 PM
