My s10 has had a slight hesitation in it since I've had it for two years. Lately it's been getting real bad. I lose speed while driving normal. U can't go over 50mph while pulling an empty trailer. I have cleaned EGR valve real good,changed plugs and wires,changed pcv valve and hose,changed fuel pressure regulator, checked cat converter, changed purge valve, all sensors, and I'm still having same problem. I have ran Lucas fuel injection cleaner through fuel system. I stated engine then sprayed carb cleaner around intake manifold. No difference. Fuel injectors all have resistance within specified range. Black grits that look like charcoal get in one of the holes of vacuum pump. I guess it's from the purge valve. I hooked a scan tool to it that reads obd 1 systems. Scan tool gave an error. It couldn't connect to the computer of the truck. What could be going on with this?
Aug 25, 2016 at 12:31 AM
