Hesitation
150,000 MILES • TURBO
MEILI
Car had issues about hesistation on acceleration. More like cutting out every second then continues to accelerate all the way to higher rpm's.
In every gear , almost feels like a TCM issue.
Found that camshaft actuators we're broken, timing chain was noisy and had major play.
Felt like the vehicle was in limp mode.
Since the repair i have put in a throttle body, a used TCM , had the ECU and TCM all updated with newest software. Mass air flow sensor, pressure relief valve, vacuum tested the turbo and waste-gate. (All working within specs). No shaft play and waste- gate opening normally and really accelerating okay, just cutting out every second as a pause.
Codes are currently only in the system but no check engine light ever comes on:
P2504 Charging system to high
U0121 Abs modual lost communication
Nov 8, 2017 at 4:09 AM
  • 55,746 POSTS
This sounds like a misfire and a plugged catalytic converter which will restrict exhaust flow causing the low power you are describing. Here is a guide to confirm the problem. Have you installed new spark plugs lately?
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please let us know what you find.
Cheers, Ken
Nov 9, 2017 at 3:28 AM
