When engine is cold or lukewarm it hesitates and sputters
158,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
2CARUSER
Hesitates and sputters when engine is cold or lukewarm.
Does not do it when hot. does this only one time, then runs
perfect.
Mar 30, 2019 at 10:33 PM
Good morning,
Any codes stored?
Can you check the fuel pressure? Low fuel pressure will cause this issue.
Also, the EGR valve could also be causing this issue if it is partially open causing a vacuum leak.
Mar 30, 2019 at 11:07 PM
