hesitates when starting and fuel smell
158,000 MILES • V6
RTHAYER0814
car hesitates when starting, and there is a strong odor of gas. the check engine light does not come on, and after it starts it runs good. Does not seem to have any leaks.
Apr 9, 2018 at 7:38 AM
Good morning.
If you smell fuel there is a leak. have someone look at the entire system from the tank up to the engine including the injectors. The v6 is tough to see the rear bank of injectors.
it needs to be done ASAP as a fuel leak is a potential for a fire.
let us know what they find so we can further assist you.
Apr 10, 2018 at 10:38 PM
RTHAYER0814
Thanks Roy,
The leak got so big that I finally saw it squirting out of the fuel damper. She is now in the shop getting repaired.
Thank you very much for your time and help.
Robyn
Apr 11, 2018 at 12:54 PM
You are welcome.
Glad to help.
Apr 11, 2018 at 8:34 PM
