Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Hesitate
Hesitate in starting
2001 FORD EXPLORER
190,000 MILES
MARCLUZZ
MEMBER
1 POST
Have to idle truck up to keep it running.
Apr 28, 2020 at 4:33 PM
Experienced Mechanic
Good morning,
Does it not start right away like an extended crank?
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Does it not crank? Please give me as much information as possible.
The idle issue could be a dirty throttle body or a idle air control valve. That is what controls base idle speed and is a very common failure.
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Apr 28, 2020 at 9:56 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
