Crank no start, crankshaft position sensor location needed
1995 TOYOTA CAMRY
300,000 MILES • 2.2L • AUTOMATIC
KAYT23
Car was working perfectly fine until one day it just would not start. The car turns over but does not start. We have changed the distributor and the coils. It is getting fire to the distributor but it is not leaving it. We are thinking it is the crankshaft position sensor, but we do not know where it is located. Can you help?
Feb 28, 2017 at 4:31 AM
HMAC300
  • 48,601 POSTS
if the distributor is getting fire then check rotor inside that may be problem. it will not be the crank sensor. also, check for a cracked distributor cap.
Feb 28, 2017 at 11:00 PM
