help with my vacumm hoses that hook to the carb.
140 MILES • 5.0L • V8 • 2WD • AUTOMATIC
GETER2RUN
Ok... I did not take the motor apart but we have been fixing this car up new heads new cooling system new timing belt etc. Well the Rochester that was on it messed up we got a new edlebrock to put on it.. Well the guy that took it apart has left me hanging for 3 wk so I decided I was going to do it well I have the carb. On and ive redone the fuel lines however I don't know where the vacuum lines are located... the only one I know is the pcv I have no idea where the timed vac. Line, the transmission vac line or the one for the power brakes is if it even has power brakes.... I am not a car gal. I have looked where the radiator is for the diagram it is not there I have looked online for diagrams. Is there anyway you can tell me where the hoses start from? Cause I can not find the diagrams.
Mar 10, 2015 at 5:33 AM
WRENCHTECH
  • 20,760 POSTS
Here is the best we are going to be able to do. https://www.2carpros.com/images/external/41886698.gif
Mar 10, 2015 at 6:01 AM
