A/C stopped working
2008 KIA SPECTRA
120,000 MILES • 4 CYL • AUTOMATIC
LUVZCATS5322
About three years ago my A/C stopped working so my dad and his friend who is a mechanic evacuated the system and tried to charge it and it did not charge it. We replaced the evaporator valve. Someone told my dad that there is not an orifice valve and others say it is somewhere behind the glove box. We have looked but did not want to damage the airbag system taking it apart. So what can my dad do to get the A/C working again? It does blow warm air and the compressor does turn on and off? Help me please, I need A/C in this Texas heat.
Jun 24, 2018 at 3:40 AM
Good afternoon.
Are you using a AC machine? If the compressor is not coming on and you are using cans, then it will not take a full charge.
How long did you evacuate the system before charging?
It has an expansion valve that is under the dash. It does not have an orifice tube at all.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Jun 24, 2018 at 4:05 AM
LUVZCATS5322
The compressor does turn on and off and everything else works. So your suggestion is to replace the expansion valve and where is that locate? They only used an EVAC machine but how can he charge it without cans? Does it have to be charged at a shop and how much does that typically cost?
Jun 24, 2018 at 4:37 AM
The machine will charge it exactly to capacity. It will evacuate the system for forty five minutes and then add a little oil and the Freon. Then if it does not turn on, you have an electrical issue that must be checked.
The expansion valve is under the dash passenger side but that most likely will not cause the system from coming on line unless it is stuck closed.
Do you have any pressure in the system?
Jun 24, 2018 at 4:49 AM
LUVZCATS5322
I will ask my dad to check pressure again, would it lose pressure if it had been sitting for awhile?
Jun 24, 2018 at 4:58 AM
No, Freon does not evaporate, it leaks out.
Jun 24, 2018 at 4:59 AM
LUVZCATS5322
When they evacuated the system they were not able to fill it. My dad's friend who is no longer around told us not to use it until they could fix the problem. So it just sat for about two years until my aunt needed a car to drive.
Jun 24, 2018 at 5:07 AM
They most likely did not use a machine to do. As I said, if you use cans, usually only one can will go in and the rest has to be installed with the A/C system running.
Jun 24, 2018 at 5:09 AM
