non start cranks will not fire?
128,000 MILES • 2.2L • 4 CYL • TURBO • 4WD • AUTOMATIC
KNIGHTY06041
  • 7 POSTS
Had RAC out to look at my car and unfortunately couldn't get it to start. I was told that the immobilizer is possible faulty.
non start
cranks wont fire
onlive data showing good rpm signal and good fuel pressure
immobiliser fault logged on scanner
suspect immobiliser fault
BRAKES
Name:EBCM (ELECTRONIC BRAKE CONTROL MODULE) - EBCM (ELECTRONIC BRAKE CONTROL MODULE) (EBCM)
DTC:C0899,Power supply circuit control unit
ANTITHEFT
DTC:U0020,Low Speed CAN Communication Bus
INSTRUMENT PANEL
DTC:U0151,Lost Communication with Inflatable Restraint Sensing and Diagnostic Module
DTC:B1325,Power supply circuit control unit
Any help please.
May 3, 2025 at 9:53 PM
  • 55,542 POSTS
Can I ask if the security light is flashing? If so, this is the problem, I would start by turning the system on and checking all fuses.
This guide can help:
If all fuses are good, please go over this video to help with the easy stuff:
https://www.youtube.com/watch?v=lXLJbuAZ4CE&t
C0899 - Device Voltage Low
U0020 - Low Speed CAN Communication Bus Performance
U0151 - Lost Communication with Restraints Control Module (RCM)
B1325 - Control Module Power Circuit Low
Confirm battery voltage is 12.4-12.6V with engine off. I have seen the instrument cluster go out can cause this problem but let's start with the easy checked first, please go over this post and get back to me.
May 4, 2025 at 4:49 AM
KNIGHTY06041
  • 7 POSTS
Thank you for helping me.
So, there is no security light on dashboard, but the EML light is on.
Have checked fuses, all okay.
Tried everything in the video, no success.
Battery holding at 12.4v.
Really at a loss with this one.
May 4, 2025 at 5:09 AM
  • 55,542 POSTS
With the key on, not cranking the engine over there is no security light on steady? Let's check for power coming out of the ignition switch when on.
Here is a guide to help with the ignition switch wiring diagrams below:
Check out the images (below). Let us know how it goes.
May 5, 2025 at 3:00 AM
KNIGHTY06041
  • 7 POSTS
The light comes on then goes out within a few seconds.
May 5, 2025 at 3:02 AM
  • 55,542 POSTS
Okay, that is normal. Please check the power above again, I updated it. It seems like the modules are not getting power.
May 5, 2025 at 3:05 AM
KNIGHTY06041
  • 7 POSTS
12.16v at the ignition switch.
May 5, 2025 at 3:41 AM
  • 55,542 POSTS
Disconnect the battery, then I would try unplugging the BCM electrical connectors and check for corrosion. Then plug them back in and clear the codes, this can reset the system, Also, I would do a hard system reboot.
This guide will show you how:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Here is the location of the BCM, also does this car have interior water damage? Check out the images (below). Let us know how it goes.
May 5, 2025 at 4:18 AM
KNIGHTY06041
  • 7 POSTS
Checked BCM wires all look fine, battery fully charged, and master reset as in your helpful guide but still won't start, starting to lose hope on this one.
May 6, 2025 at 3:01 AM
  • 55,542 POSTS
How does the engine sound when cranking? Can you upload a video so I can tell if the engine is any good or not? Or you can do a compression test. Also, did using starting fluid change anything? does the engine have spark?
Please upload videos in your response.
May 6, 2025 at 4:21 AM
KNIGHTY06041
  • 7 POSTS
The engine sounds normal when cranking, the starting fluid didn't make much difference, it tried to start but just would not go. It's a 2.2 diesel so has no spark.
May 6, 2025 at 4:29 AM
  • 55,542 POSTS
Okay, I didn't know the made this car was diesel, sorry. I would send the BCM for testing.
May 8, 2025 at 2:35 AM
KNIGHTY06041
  • 7 POSTS
I'm sorry but the advice you have given me doesn't sound like someone with 30 years of experience.
May 8, 2025 at 5:32 AM
  • 55,542 POSTS
No problem. I will see if one of our other experts can help you.
May 9, 2025 at 1:52 AM
