Problem when reversing
187,000 MILES • 3.7L • V6 • 4WD • AUTOMATIC
ZEBURNEY
Hello, when I am reversing with the wheel turned its jerks almost like a bind in the CV. if anyone could help with what it could be it will be greatly appreciated.
Jan 11, 2022 at 9:31 AM
Good morning,
Does it do it both in 2-wheel and 4-wheel drive?
Yes, it could be a CV joint failure doing this.
https://www.2carpros.com/articles/how-a-cv-joint-works
https://www.2carpros.com/articles/replace-cv-axle
Let me know so we can continue.
Jan 11, 2022 at 9:06 PM
ZEBURNEY
It's all wheel drive.
Jan 12, 2022 at 4:28 AM
It sounds like one of the axles is binding up. I would suggest replacing both sides at the same time.
You could jack up the truck and turn each wheel one by one and see if it binds up. Make sure you have the wheel turned all the way in one direction.
Jan 12, 2022 at 4:40 AM
