Help pontiac grand am map sensor
100,000 MILES • 4 CYL • FWD • AUTOMATIC
BRANDONZIPPO
Ok i have a 97 pontiac grand am se 97. Car has been,spitting and idols up and down driving and,parked. Check engine is on so i go get a engine light check and i get coded p0108. I check out the map sensor and the vacuum line had a very bad hole in it. So i changed the hose and now its running perfect but,check,engine,is still on. Please help me i cant,afford to pay a mechanic thousands of dollars.
Vehicle Make
May 3, 2015 at 6:01 AM
WRENCHTECH
  • 20,760 POSTS
You probably just need to have the code cleared. Most parts stores will do that for free.
May 3, 2015 at 8:50 AM
BRANDONZIPPO
Thank you very much check engine is off. will recommend you to all my friends.
May 6, 2015 at 4:40 AM
