Low power, spits and sputters when trying to accelerate
169 MILES
KAMI KOVATCH CLEMENT
Car has no get up and go it spits and sputters when you give gas won't go over 30. we have changed water pump, fan sensors, spark plugs and the ignition coils. still doesn't work.
Oct 5, 2019 at 2:01 AM
This sounds like a fuel issue but there are other reasons for a hesitation.
Here is a guide that takes you through the common causes:
https://www.2carpros.com/articles/engine-hesitates
I suspect the issue is the fuel pump but this would need to be tested before we just replace it.
Let me know if you are able to test the fuel pressure while the issue is happening. Let me know and we can go from there. Thanks
Oct 6, 2019 at 9:09 AM
