No crank no start issue with codes P1120 and P1221
168,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
1UAN.909W
My car listed above has a no crank no start issue .
Codes are:
P1120
Severity
Low
Powertrain, MFG, Fuel and Air Metering, Fault:20
And Code
P1221
Severity
Low
Power-train, MFG, Fuel and Air Metering (Injector Circuit), Fault:21
Aug 21, 2020 at 9:09 AM
Both of these codes are for the throttle position sensor so they would not necessarily cause the engine to not even crank.
We need to start with checking voltage at the starter. I attached the wiring diagram to help but we should have 12 volts all the time on the red wire and 12 volts on the purple wire when you are cranking the engine.
Also, when you turn the key on does the dash lights come on like normal?
Let's start with this info and go from there. Thanks
Aug 21, 2020 at 9:41 AM
1UAN.909W
Thanks, I will check purple and red wire in the morning. But yes they come on but as soon as I turn the key (while jumpstarting) it will crank for just a second then drop voltage instantly .
Aug 25, 2020 at 8:42 PM
Interesting. Yeah. Let's start with this and go from there. Thanks for the update.
Aug 26, 2020 at 11:27 AM
