A/C blowing hot air
2008 PONTIAC G6
160,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
KATHY2966
Compressor is working but it blows hot air. Sometimes just a little cool feeling. I had the Freon checked by gauges and it has enough in it. Can you please tell me what might be wrong?
May 21, 2018 at 4:46 AM
  • 110,244 POSTS
Hi and thanks for using 2CarPros.com. Based on your description, it sounds like the blend air door actuator is not functioning. Based on the door's position, you will get heat or AC into the cabin. I have a feeling the actuator is bad and is not changing the door's position. Once you reach the actuator, make sure it is not functioning when you change the temperature settings. Often times, you will get a clicking from the actuator which indicates a plastic internal gear is damaged.
Here are directions and pictures to replace the actuator:
AIR TEMPERATURE ACTUATOR REPLACEMENT
Air Temperature Actuator Replacement
Removal Procedure
Remove the fuse labeled HVAC CTRL (BATT).
Completely open the instrument panel (I/P) compartment door by pressing both tabs that support the stop bumpers. Refer to Instrument Panel Compartment Replacement.
Remove the air temperature actuator screws.
Remove the air temperature actuator.
Disconnect the air temperature actuator electrical connector.
Installation Procedure
Connect the air temperature actuator electrical connector.
Install the air temperature actuator.
Notice: Refer to Fastener Notice.
Install the air temperature actuator screws.
Tighten the screws to 1.5 N.m (13 lb in).
Close the I/P compartment door. Refer to Instrument Panel Compartment Replacement.
Install the fuse labeled HVAC CTRL (BATT).
I hope this helps. Let me know if you have other questions.
May 21, 2018 at 11:48 AM
KATHY2966
Thank you so much. I will try it tomorrow afternoon if it do not work. I will contact you, again thank you.
May 21, 2018 at 12:03 PM
  • 110,244 POSTS
Glad to help. Let me know how things turn out for you.
May 21, 2018 at 12:36 PM
