Shuts off while driving
2003 FORD FALCON
250 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
JEWWIE
So I have the car listed above sedan bought it not long ago. Was running awesome for me until I took it for a drive one day and it just started cutting out when I was driving and started to stall at lights. I have changed body control module and ICC and have not had any luck it’s actually gotten worse. Now it cuts out heaps while driving only if I put my foot down like half way or right down it will spit and spat at me .also only sometimes when I go around corners or even just doing a u-turn it cuts in and out. Help would be much appreciated i have spent lots of money trying to fix it myself as I thought it wouldn’t cost as much as a mechanic. turns out I should of sent it there straight away. Thanks in advance!
Nov 20, 2019 at 2:03 PM
STEVE W.
  • 15,349 POSTS
Your description sounds a lot like low fuel pressure, especially if turns effect it as the fuel moves around in the tank. I would start by checking the fuel pressure at the rail with the engine running. Then see if the pressure drops off fast when the engine/key is shut off. A bad pump in a 2003 wouldn't be an uncommon thing.
Nov 21, 2019 at 2:31 AM
JEWWIE
Cheers Steve. I’ll check it out tonight. thanks for the reply!
Nov 21, 2019 at 3:57 AM
