1994 Ford Falcon The engine stalled three time today.
SIAKI
  • 1994 FORD FALCON
Engine Mechanical problem
1994 Ford Falcon 6 cyl Two Wheel Drive Automatic
Hi there, I have a ford falcon ED 94 sedan, as I was on my way home, the engine died, and I waited for 10 mins and started up and it goes again. It happens four times last month. The engine stalled, and I waited for approx 10 mins and started up and it goes again, the only thing I can think of is the fuel pump maybe need replacing. Or maybe something serious. Your answer will be appreciated.
Thank you
Wednesday, March 18th, 2009 AT 3:10 AM
Next time it dies out don't wait 10mins do below immediately to determine if its fuel or spark problem
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, March 18th, 2009 AT 3:29 AM
