I changed the oil pump, the timing chain guide because it broke and the lashers . Does the timing chain tensioners have anything to do with it? I’m afraid the journals might be clogged have no idea how to unclog them with out having block boiled . Any suggestions would be awesome.
Mar 19, 2020 at 2:08 PM
✓Experienced Mechanic
The tensioners are driven by oil pressure.
Are you planning on removing the engine? The possibility of clogged journals being clogged is next to nothing.
I would suggest replacing the engine with either a rebuild or a good used engine.
Mar 19, 2020 at 9:37 PM
RINEHART
MEMBER
What other engines will bolt up to the transmission and air right down in the truck?
Mar 21, 2020 at 1:17 AM
The 4.6 will bolt up with some modifications but you are better off sticking with the 5.4.
