Key will not go pass ACC
2008 VOLKSWAGEN JETTA
214,000 MILES • 2.5L • MANUAL
CHRIS JONES4
Key wont go pass acc. no window power, no sunroof, no trunk, no dash, no start, help.
Nov 22, 2020 at 3:05 PM
Is there any history to this? Meaning did you just buy this vehicle or did you come out in the morning and it was doing this?
I would suggest we start with the basics and check the battery and make sure it is okay.
Then when you say it will not turn past the ACC position, will it even make it to the ACC position? Clearly when in that position all these functions should work so that is why I am wondering if we have a battery issue.
Let's start with that and go from there. Hopefully this will turn something up so we have more to go on. Thanks
Nov 23, 2020 at 3:01 PM
