Will not start
200,963 MILES
TONY KROPACZEWSKI
Light on and buzzing noise car won't start. took off battery cable off when put on lights come on key is off.
Jan 13, 2022 at 9:45 PM
Just to confirm which light you are talking about, is this the check engine light?
If so, we need to check the codes and see what is there.
Also, if this is just cranking, we are going to need to check for fuel and ignition. However, this buzzing noise that you are hearing does that happen only when you are cranking the engine?
If so, this could just be a drained battery.
If this doesn't sound like what you are dealing with then we need to start with getting a video of this issue so that we can get on the same page.
Please let us know what you find with this, and we can go from there.
Thanks
Jan 14, 2022 at 7:33 AM
