help finding a wire?
88,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
NIKOLAIT
  • 18 POSTS
Hi-
I've got the vehicle listed above, VIN: JM3KE2CY9F0478828. I need to identify the wire on the rear body control module that turns on the reverse gear back-up lights.
The part number on the module is KD45675YOG
Do you have access to this kind of info?
Thanks!
Dec 20, 2022 at 6:24 AM
  • 110,246 POSTS
Power to the rear body control module (RBCM) is provided via the meter 1 fuse in the engine compartment fuse box.
Power from the fuse goes to the RBCM via a green wire with a black tracer. From there, power is triggered via the CAN, and power is sent to the backup lamps via a white wire with a black tracer.
I attached the schematic below. Let me know if this helps or if you have other questions.
joe
See pic below.
Dec 20, 2022 at 10:17 AM
NIKOLAIT
  • 18 POSTS
Thanks Joe! Exactly the info I needed :) My backup camera is working fine now. This is the second time you've been a big help! Mahalo
Dec 20, 2022 at 12:59 PM
  • 110,246 POSTS
I'm glad to hear it helped. Also, I have to assume you are in Hawaii with the Mahalo. Boy, I envy you. LOL, it's going to be 0 degrees here on Christmas day.
Regardless, take care of yourself and I wish you and your family a great Christmas. Also, feel free to come back anytime in the future.
Dec 21, 2022 at 10:28 AM
