My truck sits and then dies
130,000 MILES • V8 • 2WD • AUTOMATIC
THOMPSONJ
My truck sits then it dies. I put jumpers on and I jumped it. As soon as I get it started it dies, I can crank it over and no start again. I have to keep my foot on the gas pedal for it to stay running. When I let my foot off the gas pedal the truck completely dies.
Mar 19, 2016 at 9:18 AM
JDL
  • 16,098 POSTS
Make sure the battery has a full charge, if it is down, use a charger and get charged up. Make sure battery connections are all good and charging system is okay.
How long since a tune-up? Any applicable trouble codes? With some makes and models, if the battery voltage is lost, it could cause problems with some modules? Those modules may have to relearn or be reprogrammed.
Make sure you security system isn't causing any problems.
With idle issues, check and clean idle air system.
If the battery is down, we're just spinning our wheels, with testing. Just my opinion.
Mar 19, 2016 at 10:18 AM
