Crank no start issue
199,000 MILES • 1.5L • 6 CYL • 2WD • AUTOMATIC
RIVERSSUE
We have replaced fuel pump. ignition coil, starter, wires and spark plugs, new battery, filters, changed oil and oil filter. It cranked two times and went shut off right after installing the starter. We checked engine is getting plenty of fuel it just will not fire. I do not know what else to do.
Dec 4, 2017 at 3:29 AM
  • 110,248 POSTS
It could be many things. If you are sure the injectors are sending fuel into the combustion chamber, my next question would be, is it getting spark. Here is a how to for checking. Do that and let me know what you find. Also, if there is spark, rent a noid light at the local parts store and attach it to the wiring which goes to each injector. It should strobe if they are getting power.
Dec 4, 2017 at 10:07 AM
