car stopped running as the result of a multi misfire
256,854 MILES • 2.7L • V6 • RWD • AUTOMATIC
ROBERT HOUGH
it stopped running on me due to a multi misfire. so I changed out the spark plugs and coil packs. it will start, but it wont stay running. soon as I get down and idle mode it wants to cut off and it starts acting rough. need help figuring out what my problem is.
Oct 2, 2016 at 5:02 AM
HMAC300
  • 48,601 POSTS
for this kind of problem have a mechanic look at it as you can dump a ton of money in it and still not fix it. misfires are hard to diagnose he can freeze frame it to see if it is a sensor or low fuel pressure etc.
Oct 2, 2016 at 9:06 AM
