car wouldn't even crank
233,560 MILES • 4 CYL • FWD • AUTOMATIC
STEVEN BOGGS
One day went to leave and the car wouldn't even crank. The dash lights and digital clock stayed on and bright. All I heard was the buzzer alarm pre ignition and a single click. I switched from park to neutral to no avail. I tapped the ignition, jiggled the keys in the ignition, locked the steering wheel, checked the fuses and ignition relays all with no luck. A few minutes later my wife goes out and jiggles the the keys and bam to my disbelief it starts! Then after two starts it's doing the exact same thing. I even replaced the ignition switch cause it looked tired. I don't hear anything at all from the starter, not even the bendix. Just a single click when I try it. What do I do next. Starter replacement looks tedious. Any ideas?
Aug 27, 2016 at 9:47 AM
RENEE L
  • 1,260 POSTS
You have a bad battery connection, here is a guide that will help you.
Please let us know what you find so it can help others.
Aug 31, 2016 at 11:52 AM
